15 hours ago, calania said:he problem I have that if I write "M109 S200 " in the start Gcode after the G29 command nothing will happen since cura already heats the extruder/ bed before running the start Gcode.
Note that Cura *only* adds its own preheating before the start g-code if it does not see {material_print_temperature} or {material_print_temperature_layer_0} in your start g-code snippet. If you use those strings instead of hardcoding a value, Cura will not have to add its own preheat sequence.
nallath 1,123
On what printer are you printing? Because if there is something happening that isn't in the g-code, it's not Cura doing it.
