Owens Corning - XSTRAND GF30 PA6
SandervG
Posted · Owens Corning - XSTRAND GF30 PA6
Owens Corning makes XSTRAND GF30 PA6 available to Ultimaker users via our material alliance in Cura.
You can access all available materials via Cura > Marketplace > Materials.
Are you curious about others experiences using XSTRAND  GF30 PA6 or do you have any other questions regarding this filament? Feel free to post them below.
Some links you might find useful:
Safety Data Sheet
Printing Guidelines
    • 10 months later...
    Strange, I just tried it here and it works as expected. Installed the material and restarted Cura.
    497867456_Bildschirmfoto2019-09-30um12_12_08.thumb.png.8f0ede71ed75b2e38de7930286ee79e3.png
    Have you tried to uninstall and install it again?
    This is what I am getting when I uninstall and re-install the material. Weird. Can't seem to find it anywhere.
    Is there a way where I can download the material online then import it to Cura?
    As far as I know, no....
    @nourelmenyawi I would try a fresh clean install of Cura. Your installation also lacks the Ultimaker materials as far as I can see. For a clean reinstall, you have to remove all data in the configuration folder. Help->Show configuration folder shows you the the way.
    I will do and try again and let you know. Thank you for your help.
    I have managed to find it in the second extruder but not the first extruder. Any idea why this is happening?
    Oh, I missed that one completely. You selected the CC 0.6 core. The material you want to print has no profile for that print core. Therefore it is not in the list. Select an AA 0.4 core in extruder one and you will have the material available.
        • 1 reply
