1 minute ago, smartavionics said:Is it possible for you to attach the project file? Thanks.
Hello Smartavionics,
Thank you for your reply! I have attached to project file to this post.
Knoose
Knoose
I have attached the file to a post but I think it still needs to be moderated.
Thank you for checking it out,
Snap, I really need the negative horizontal expansion because else it will print my holes slightly too small for all sorts of screws.
On the other hand it already did this before I started to use horizontal expansion (but obviously less as can be seen in your second image).
Guess I have to recalibrate my x and y axis instead of this shortcut 🙂
Thanks again!
Kind regards,
Knoose
4 hours ago, Knoose said:I really need the negative horizontal expansion because else it will print my holes slightly too small for all sorts of screws.
Due to several reasons, holes are always printed smaller than designed. Using the horizontal expansion setting can compensate the dimensions for the hole, but also for all other dimensions in x/y. So, in my opinion, this is not an option, because I want to have dimensional accuracy over the whole object and not only at the holes.
Normally you have to design holes slightly larger and then they will fit your screws.
37 minutes ago, Smithy said:Due to several reasons, holes are always printed smaller than designed. Using the horizontal expansion setting can compensate the dimensions for the hole, but also for all other dimensions in x/y. So, in my opinion, this is not an option, because I want to have dimensional accuracy over the whole object and not only at the holes.
Hello Smithy,
Thank you for your reply, you are right of course, the few times I have designed my own items I had taken into account the offsets. Sometimes I just like to just pull stuff from thingiverse without the trouble of adapting it. Still I am aware my x and y axis are slightly off which does not help either.
24 minutes ago, Knoose said:Sometimes I just like to just pull stuff from thingiverse without the trouble of adapting it.
In that case, I drill the hole after printing and you are done 🙂
But I know, it is not possible for every model, but normally it is easiest and quickest way.
burtoogle 506
