Hmm odd. I was thinking about hairy stuff as it ran almost 1 year continuously, and there was / is a lot of dust. Got rid of most of it, but what strikes me is that the fan seems to run fine for a second after switch-on. Later dead... Looks like a case for warranty.
Thanks,
Christian
Smithy 1,085
Normally you get a lot of problems if the front fan is not working. The fan cools the upper part of the print head and the fan start automatically if the print core temperature is higher than 40° or 45°. Usually some plastic blocks the fan if it is not working, so check again if there is anything around the fan.
fbrc8-erin 263
The most common reason for the front fan to fail is usually that little hairs of filament get wrapped around it. You can clear these out with a pair of tweezers; if it hasn't been stuck too long it should run again once the hairs are removed. If it's spent too long trying to run but unable to, the motor on the fan itself will be burnt out and the fan will need to be replaced.
