Smithy, I just noticed a small black square with 2 circular arrows and a red line thru it. What is it? It's at the end of some menu items
Disregard.... its the Cura settings plug in
Edited by joestefanoSmithy, I just noticed a small black square with 2 circular arrows and a red line thru it. What is it? It's at the end of some menu items
Edited by joestefanoNope, don't know what it is. lol
Post a picture what you mean, I think it is easier.
That is strange, I have never seen it before, sorry!
Edited by SmithyMust be a plug-in or something. doesn't seem to have an effect on anything
Hello. This is my first post. I'm new to 3D printing and to using Cura software. I don't seem to be able to change some of the settings in Cura. For instance, I have the Infill Pattern box checked but don't seem to be able to find a way to select a pattern. When I hover over the words it tells me that I should be able to change them but I don't know where.
Thank you.
When you set the infil density above 0.0%, it opens a new menu 'infill pattern'
Smithy 1,107
When you switch the tab to customize you find all settings and their values. The recommended tab with its settings just set the values in the customize tab.
