Posted · Cannot load Cura 3.6
As I am keen to keep up to date, I foolishly decided to install Cura 3.6
It will not install.   I tried uninstalling my other versions manually and it still will not install.   I tried install as administrator.- no better.  SO installed 3.4 without a problem
Am I alone in having this problem
BTW I have a Windows 10 Surface Pro
THanks
    found this via google
    Quote
    Import problem solved by the following steps:
    1. Either edit setup_win32.py and simply change 'Arcus' to arcus or modify the Arcus installation folder to 'Arcus'
