5 hours ago, aag said:I am using the AA0.8 print core
I would not use the 0.8 print core for such a small part. You will get more imprecise problems than you can save time. If you really want to use the 0.8 core you should keep your min. layer time high, set it to 10sec or more, that the previous layer can cool down and print slowly.
I would recommend a gap of 0.4 mm, maybe more between the parts. But it is a trial and error process. So I usually cut the model in Fusion 360 in a very small part and make a test print, just to see if the gap is ok or if I need more (or less). With splitting the body you can quickly print a test part without waiting too long for a result. With construction offset planes in Fusion this can be quickly done and after your test, rollback in the history line and you have your body again in one part.
1
kmanstudios 1,117
I would start with a 0.2 - 0.4 mm difference in gap between parts.
