Are you sure the PEEK part melted? Or did you just get some leakage? Sometimes PLA leaks out through the edge of the PEEK. PLA can turn brown or black if you keep it hot for too long.
If it melted then something is wrong with your temperature readings. You need to fix this before replacing the PEEK part or you will melt it again.
SandervG 1,522
I don't think you can un-melt your PEEK, so a fix would be to order a new one in the shop.
To find the cause, do you know if your blue led was burning while you were printing?
If it wasn't, your signal cable got disconnected, making it impossible to communicate the temperature to your electronics.
Resulting in infinite heating.
You could fix it by guiding the wires through the strain relief so it can not get disconnected again.
