yellowshark 153
If you have the model loaded in Cura 3.xx can you go to the scale icon on the left hand side and tell us what the x/y/z dimensions are please.
Sorry...
It's a Ultimaker 2
Here I loaded a very small item and showing the scale:
The machine settings regarding the buildplate are:
Thanks for answer my post by the way:-)
Have you created the Cura printer profile from scratch after updating Cura or was it the profile you had before?
So maybe there was a problem with updating the printer definition/configuration and maybe it helps if you delete the printer in Cura and add it again.
Yes, and I'm using the default settings and have also tryed on different computers.
ahoeben 1,968
You don't give us much to work with. What printer do you use? Can you attach a project (File -> Save...)?
