Thank you for your answer nallath.
So how do I update through the Ollimex board? The thing is I cannot update through the firmware through the two normal ways as it thinks it is an ultimaker 2+
Is there no way of doing it via the usb connection on the Ultimainboard 1548-I ?
Or if I have to do it through the Ollimex board - how do I do this?
Thank you in Advance
nallath 1,101
The files you downloaded are the packages that are installed on the ARM board on the machine. The mainboard is updated by the ollimex (the arm board).
