Thank you for the fast reply.
My fan duct is placed in the front, so the air should go to the front of the objects. But even if the fan would be the problem (I don't think it is, but tomorrow I will give it a try at 10% speed), why didn't I have any problem so far (I've attached an image of the incomplete seesaw model)?
Smithy 1,131
Hi
it looks like under extrusion, but why only on one side? So I guess it is not under extrusion, but maybe your cooling fan is blowing too much cool air on this side and you get some kind of warping of the layer itself before it can get bonded to the previous layer.
Check if you fan, I think the A8 has only one, is on that side. If so try to decrease fan, 75% is normally too much for ABS, turn it off completely or try around 10% fan speed.
That said, printing ABS without an enclosure is very difficult to not possible. You need an enclosure around your printer to keep the warm air inside.
