I'm changing diameter setting in Material---Diameter.
I try some diameters like 2,85-1,75-1,00-0,5 and the print time increases a lot when the diameter is lower.
i don't work with ABS or PLA but with food material.
What kind of printer is this?
Delta Wasp 2040
gr5 2,069
The extruder should speed up and the X,Y speeds should stay the same. How are you changing diameter setting? In filament settings?
