cat1 - this is definitely spiralized, the z value alters with every line segment from layer 5 upwards. Perhaps you should reduce the number of bottom layers so that it spiralizes from a lower layer?
cat2 - make sure the wall overlap compensation is enabled and set the Minimum Wall Flow to something like 20 and then it should print those walls without doing the return trip.
burtoogle 508
Hello @tryhardcoffee, I looked at your gcode files:
Hope this helps.
