I think more like this:
https://www.amazon.com/Zi-Rui-PLA-Multi-Color-Dimensional/dp/B077HVRNBX
One spool, different colors.
Thank you for your replies ahoeben and Smithy. Yes those are similar yet different enough to be of different purpose. Here's why.
ahoeben's link goes to the Palette which does filament chopping and splicing to create exactly what this idea accomplishes, but with almost zero waste. However it's cost is $600 to $900 depending on what you buy and there is no 2.85mm solution, only 1.75mm.
Smithy's link is really cool also, a rainbow filament that paints rainbow colors in your print. This one does a similar thing but does not place colors in a controlled way.
It was the kind of stuff you show that led me to think of the one I imagined. The difference here is that no or nearly no equipment is required, just buy or make the special filament and accurately position it in your printer, use the special slicer to make your gcode, and let it print.
I hope that's a little more clear. Your examples are helpful, thanks again.
Les
So you mean, your solution is like the rainbow spool, but in a controlled way. Means you slice the object with your slicer, get some information on how which filament with the exact length you should splice together and then print off this spool your object, right?
The way you mention is pretty close. In fact, in the original emails that is one idea that arose.
The original version is a little bit different. You buy or make a spool of pre-sliced filament. This spool has say: black and white filament alternating with lengths of 100mm each. So we have 100mm black, 100mm white, 100mm black, 100mm white and so on.
We slice the STL file with a custom slicer that knows this and directs filament where needed, either filament where optional (such as infill), and discard prints on the corners and edges when fast-forward (waste) printing is required.
Then we line up the filament by feeding it in and extruding it until black shows (clearer color to see) and then run the gcode from the slicer. If all goes well we get a gray-scale (dithered) black-and white object.
Does that make the idea a bit "clearer" (pun intended)?
Les
p.s. if we are making our own filament, then the approach you mention uses less waste. If we are buying the filament then it is the opposite. Or so I believe.
I can see no way to implement that concept that is not extremely wasteful.
Yes I agree. This concept is extremely wasteful.
If you need a mixed print and all you have is a single nozzle printer, it could do the job.
Les
ahoeben 1,956
So, like this?
https://www.mosaicmfg.com/products/palette-2
