When you use a 0.8 core, Cura changes some more settings than just the line width and therefore you will save material. I cannot say why or which setting it is exactly but maybe the support structure is different.
With an 0.8 print core you can save a lot of time. I have only the AA core but I use it a lot because it is faster than the 0.4. I often print with 0.3 layer height and get still decent surface qualities.
Carla_Birch 92
If you wish to save on PVA you can print with PLA supports with just a PVA Roof, this is something i personally do and it greatly saves on time and cost. But you can only really do this if the supports are in places where you can still remove the PLA support.
But if the model is one where you can do just that you save time and money why keeping the benefit of a smooth underside on overhangs that PVA gives.
As for the above it could be due to prime tower, 0.8 will do a wider wall around the prime tower than 0.4 would, this is just a guess i have not looked so try it without a prime tower (if you are trying with one)
