Execute PostProcessing Plugin - bug or feature?
nagygabor679
Posted · Execute PostProcessing Plugin - bug or feature?
I wrote a little PostProcessing Plugin. After I clik Extensions / Post Processing / Modify G-Code menu, I  can select it, I can set paramteres.
I can load any stl, everything working fine. But...
If I click Save to removable drive or Save to File button then the plugin will be executed, if I click Print via USB then the plugin  will not executed.
I'm sad, because I always printi via USB, and  it's very uncomfortable for me.
So, is it a normal working method, the post processings plugins executed only when I save G code?
Or is it a bug,  the post processings plugins should execute, when I'm printing via USB?
(I tested it with Cura 3.6 and 4.0 beta.)
Thanks,
Gábor
    • 4 weeks later...
    • 2 months later...
    same issue   cura 4.0.0  ender -3😪
    sorry for posting so often,  I had registered the account afterwards and all not working posts appeared suddenly.  sorry
        • 56 replies
        • 29 replies
