No, I didn't touch those.
I just sliced it again and the problem is gone. Weird.
I don't believe it. You changed something.
Anyway I've seen similar problems. Text is usually added to the CAD late and they don't always do it right so that you have all kinds of edges/walls to the text *inside* the model. This kind of thing is fixed with the "fix horrible" settings.
No I didn't - I swear. And I didn't check the fix horrible setting.
I suspect it hast something to do with shell thickness. If it is to small, the text would be "sliced away". Maybe a calculation in Cura went wrong or it was borderline to a value that would slice away the text.
look at it in xray view. If you see *any* red then you cad model is illegal. You can fix it or you can experiment with the "fix horrible" settings. There are 11 combinations of those settings to try. (don't do A *and* B as it is the same as B).
illuminarti 18
That's very weird. Slices fine for me in Cura 13.06.5... you don't have any of the 'fix horrible' expert settings selected do you? Maybe those could eat the geometry?
