I Hope you are right. And i have to adopt my workflow, start the machine, and check the led function, and only then start the print.
On 1/13/2019 at 10:58 AM, Carla_Birch said:It's just a bug that seems to have come back, once you can reset your machine it will be fine and with luck the next update will fix it for good and its also due to add support for LED's going totally off and not just dim. So i would wait it out before cutting into wires on a £6k machine.
It was great to read your reply; thank you.
Carla_Birch 115
