There are two gcode samples attached. They are from the same STL file, with the only different being the print temperature and combing being turned on/off.
200.gcode has combing turned off, it does not make the thumping sound when printing, but has surface blobs.
195.gcode has combing turned on, it does make the thumping sound, but does not have surface blobs.
burtoogle 514
Hi @Bad_Mechanic, please attach a sample of the gcode that exhibits this problem so it can be investigated. Thanks.
