Unfortunately I can not take pictures in the office, but I will try to explain it a little better.
I replaced the standard Bowden tubes from the feeders to the print head and had a small piece left over (10-12 inches).
I knew I wanted to protect the filament between the box and the feeder and wanted to use a tube to help it feed better/ properly. At first I thought about making a stop to keep the tube from being fed or ground up in the feeder, but when I looked at the pictures of the feeder from the maintenance page, there is already a tapered section in the feeder before the gears, so I just placed the leftover piece of tube between the box and the feeder and when the feeder pulls its tight and smooth.
I just changed materials and checked the end of the Bowden tube going into the bottom of the feeder and it shows no signs of wear.
Smithy 756
BTW your spacer can also be used to make some additional holes to feed the filament from the bottom and not from the top case. The Polybox has all openings in the top case, so when you lift the case you have to fiddle with the filament. So it is better to feed the filament through a hole in the bottom part, but if you don't want to drill your Polybox you can now drill it in the spacer. Another great use-case.
