fbrc8-erin 263
Your reseller should be able to order the part in for you. It's a T-shaped threaded piece--the T/flanged part sits against the panel while the threaded part mates with the screw to hold your feeder on.
Thanks for the help!
Unfortunately I have already spoken with my supplier, which is not able to provide me with this part here in Germany.
I did some research, according to the UM3 Bill of Materials, the missing part should be a "Threaded Insert Multisert 004M3" (Part No. 2867 B).
I think i found the insert at the manufacturers page (see screenshot), but I only found b2b resellers in larger quantities.
Do you know if there is a supplier (globally?), where I can buy the part from?
Hi @Horenz,
Have you seen this one, selling Tappex product in Germany here:
https://www.kvt-fastening.de/en/productsearch/?q=004M3
Thanks
Torgeir
2 hours ago, Torgeir said:Hi @Horenz,
Thanks
Torgeir
Hi Torgei,
thanks for the help! Yes - i found this retailer. Unfortunately it is only B2B and the minimum order quantity is 100 pieces!
fbrc8-erin 263
The motor cover is just held in place with tabs. Put your bed all the way at the bottom off the printer, and then pull on the top corner of the motor cover kind of diagonally. It may put up a bit of a fight; it's a tight fit.
Press the threaded inserts back into the correct position on the inside of the printer; if need be, you can screw the screw into it with it not quite seated and it will pull it through the rest of the way, and then you can take the screw out and screw your feeder back on.
Horenz 0
Hello there,
sorry that I pull out that kind of old thread, but I have the same problem as the original poster. But i somehow lost the brass fitting for the screw.
Is there any chance I can buy this brass screw fitting somewhere? Right now I am only able to use one extruder...
Thanks a lot!
