Posted · Some layers are darker than others
Hey,
I dont know why some layers are darker than others on my printed objects.
I use white Ultimaker PLA.
The object itself is pretty smooth and the corners as well as you can see in the photos.
Maybe It is Z Wobble but I am not sure. Do you have any ideas?
    I've checked the height of the object as well and it has the height it should have. I believe it wouldn't be Z Wobble if the model has the desired height. Am I right?
    From the looks of it I would say that the darker layers are under-extruded layers.
    Printing slower and cooler didn't help. The printer doesn't have play on the X/Y axles as well. I'm pretty desperate right now.
    On 1/31/2019 at 3:28 PM, Framar said:
    What material/color were you printing prior to this print?
    I've only printed with White PLA so far. In the beginning there was a bit of grey PLA inside of the nozzle from the factory test print.
          • Heart
        • 4 replies
