thank you, here are the results:
Disabling windows firewall lets cura not start, but
disabling avira virus scanner (windows firewall is enabled again) lets start cure normal!
If avira virus scanner is enabled then cura 4.0.0 runs only in "windows8 comatibility mode".
whats to do that cura runs with enabled virus scanner normal under Win10 Home 1809?
Edited by superbike
nallath 1,098
By the looks of it, something is messing with the connection between the front-end and the backend. Could you try to see what happens if you disable your firewall / virus scanner while you start Cura?
