Hi Nicolai.
Warp deformation is happening because different parts ot the printing piece have different temperatures.
You mentioned that you opened the door and let the cool air in to the chamber... This can cause warping 99% of the times..
Usually to keep temperature of the part more or less equal we use heated bed.
I would try to not open the door at all during the print since melting point of the whole part will never be achieved inside...
Happy printing!
ultiarjan 1,209
I see you basically are posting the same question 2x, and I now see you do use a top cover... thats good.
Again, I would try the adhesion sheets...
https://ultimaker.com/en/resources/22231-how-to-print-with-ultimaker-pc
Adhesion
Ultimaker PC is not an easy-to-print material because it tends to warp and delaminate if the printing environment and settings are not perfect.
We strongly recommend using the adhesion sheets to achieve the best build plate adhesion when printing with Ultimaker PC. Alternatively, you can apply a thin layer of glue (included in the accessory box of your Ultimaker) to the glass build plate, but please note that adhesion with glue is less reliable than with adhesion sheets.
