Thanks Smithy. I just tried, but the shaded area did not change and I get the same error messages. I'm on a MAC also, not sure if that matters.
There are also several other features which reduce the print space, like brim, prime tower etc.
Check if you have bed adhesion enabled and if so turn it off, if still not possible to slice turn off the skirt too.
That did it, thank you!
You are welcome and thanks for the feedback.
Smithy 1,131
When you use both print cores then the build volume is smaller. So if this is a single extruder print you can try to disable the extruder 2, to get a bigger build volume. The shaded border will get smaller.
You can disable the extruder in Cura menu -> Settings -> Extruder 2 -> Disable Extruder
