Yeah, realizing how specialized a beast the Lulzbot edition is. Incidentally, I'm getting support if I set a model off the buildplate, so problem solved, if somewhat clunkily.
Thanks
Thanks
In that case, it's maybe easier to print a raft?
I’ve tried rafts with the same problem. It will slice the raft, and then start the supports 3-4 layers above it.
nallath 1,125
I don't know what changes lulzbot made to their version of Cura, so there is little I can do to help with that. I suggest you contact them and ask for support.
