It is a font (configuration) issue. The gcode boxes (try to) use the system-defined non-proportional font.
here they are. The cura.log is just a copy of both stderr and stdout, i guess.
What i forget to mention is that i tried to see the file accesses of both the user and root program run. But i couldnt find something promising with lsof so far.
I also tried strace which didn't work because it makes cura freeze. But i'm not experienced with strace so i don't know if you could give some valuable information.
I knew I had seen it before in an issue:
Well, that shows that my memory is rubish.
Finally, its solved! Thanks guys. This has shown the way and has lead me to
http://perlstalker.vuser.org/blog/2011/12/19/setting-default-monospace-font-xfce/
My Problem was somehow in the $HOME/.fonts folder. There were some monospace fonts (.ttf and .otf) of some older Powerline installation. I just got rid of the folder and now the squares in the GCode section are gone!
Powerline seems to work as before.
This solved the problem:
https://github.com/Ultimaker/Cura/issues/2452#issuecomment-613903842
QuoteLinux Mint 19.2 Cinnamon
Same problem,sudo apt purge fonts-powerline
fixes the problem.
nallath 1,120
oh, wow. I've never seen it do that before (which is one of those things you never want to hear from any engineer I guess).
Could you share your logs? I don't think there is going to be anything in there that is usefull in there, but it's worth a shot.
