Posted · Settings visibility
Had a look in the manual, but still not clear on this...
If a setting is not visible, is it not in use? Or does it just run at the Cura default?
For 2 examples.
1) If travel speed is not visible in Cura, will it use the default travel speed in my printers firmware?
2) If Jerk control is Enabled, but the settings are not visible - would that be using my printer firmware defaults, or just unseen Cura settings?
Thanks in advance.
    No, a setting's visibility has no effect on whether it is used or not by Cura. All the settings have a default value which may or may not be suitable for a given print job.
    Ah, so even if a setting is not visible, it could still be doing something in the background - you just can't see the values.
    Is there a way to reset all the values to their defaults? Or is it a case of uninstall / re-install?
    Correct.
    Not sure that an uninstall will actually remove your settings. Someone who knows the Cura front end better than me needs to answer your question. It does seem somewhat of an omission that there isn't a "reset profile to defaults" option.
    Well, trying the reinstall - first question is if you want to remove all your settings... which I do, I really do.
    I am unable to print without strings. I have been working on the settings and nothing is helping, so I am hoping something was changed in Cura at some point which is messing me up.
    Retraction, esteps, jerk, travel, speed, temp, coasting... tried it all (and probably more), still stringing. Please be something I did in Cura…!
    here's a list of all folders to delete to get a real clean install;
    https://github.com/Ultimaker/Cura/issues/3051
    And are you aware of the visibility settings button? you may want to select "show all" to see if there are messed up settings..
    The settings not shown by default can indeed F@#$up you print...  I particularly always check for crazy speeds, like to fast infill speeds...
    Posted (edited) · Settings visibility
    Hehe, yeah thanks.
    That's actually kinda why I asked the question. A while back I got fed up with adding settings here and there so clicked the show all option. What I was worried was by doing that, I activated a lot of things I didn't need. Guess that was not the case, I must have changed something somewhere that had a knock on effect.
    For me, I backed up c:\users\myuser\appdata\roaming\cura and then uninstalled Cura. It asked me if I want to delete all my settings too, which I said yes to.
    Since reinstall and all the settings being back to day one, things are looking a lot better... though I still need to do some more tinkering. However, today I also found the basic\advanced\expert views you mentioned, so I am sticking with Advanced and just adding what I need to start with so I don't get tempted to fiddle with too much in one go.
    Thanks for your help everyone.
    P.S. I did get a 99% string free print out on my 2nd try after reinstall - best I had before that was 95% or so, often much worse.
    Edited by DivideByZero
