tinkergnome 922
The maximum z speed for the UM2(+) firmware is 40 mm/s. The same speed is used for "homing".
The default profiles in Cura do not limit the z speed, so 40 mm/s will be used for layer changes too.
But the max. acceleration for z is only 100 mm/s2, 40 mm/s will be probably never reached for short moves.
I think, it doesn't matter much for the (very short) moves during a layer change. Personally i use 20 mm/s as the max. z speed in S3D and noticed no difference.
Hope that helps!
1
RetromanIE 40
Anyone from Ultimaker have the details on this?
