LIMIT SWITCH HASN'T PROBLEM BUT ER17...WHY?
dminsb
Posted (edited) · LIMIT SWITCH HASN'T PROBLEM BUT ER17...WHY?
Unexpectedly today, While I changed the material,
My Ultimaker3 show me the error massage "ER17 - The X or Y axis is stuch or the limit switch is broken", at the same time with the Head trying to move more back & left
(with a sound 'ddadadadadadadadadaa~~~~~~!@!@!@'),
Although it has already arrived at home position.
(troubleshooting : ER17)
https://ultimaker.com/en/resources/23151-the-x-or-y-axis-is-stuck-or-the-limit-switch-is-broken
But the limit switch has working while "System > Maintenance > Print Head > Home.
So, I think the switch is not broken physically. it works...
So why?
Is there anyone has the problem same with my case?
How did you solve that issue??
Edited by dminsb
