Missing feature multiple layers of brim
seraser
Posted (edited) · Missing feature multiple layers of brim
Hello, there are a missing feature basical to avoid warping with ABS, multiple layers of brim option, other slicers can do it but Cura with "thousand" of options no, please, add this feature, with 4 or 5 layers of brim and ABS warping gone totally with Big pieces.
Thank you.
Edited by seraser
18 minutes ago, Smithy said:
You can use a raft instead of the one layer brim.
Thank your for your response but I like brim because the contact of the piece with crystal give bettter resolution of the base.
Edited by seraser
    • 2 weeks later...
    Posted · Missing feature multiple layers of brim
    Maybe you could design it in the CAD file, like I often do for custom supports in hard-to-access areas? Then you can give it all the features you want.
    Question: how do you remove such a thick brim? Isn't that too hard to cut with a knife?
    • 1 year later...
    I also think this would be a really useful addition and probably won't be very hard to implement (just an uneducated guess).
    "A bit" more complex but probably also more effective would be to increase brim thickness (and width) only on corners of the model; with an adjustable angle that determines which corners will be super-brimmed™. Similar to mouse ears but kind of semi conical radiating away from the corners. Hard to describe but I hope everyone gets the picture.
