Hi smartavionics,
it took me whole day to figure it out.
It is a Bug. If I turn Combing Mode off, my model prints
just fine.
Hi smartavionics,
just fine.
Hi @nobio8, could you please attach the STL file so that I can try slicing using your profile. Thanks.
О да вашейв😉your builds are wonderful))) keep up the good work))))
Edited by qwerty822445 minutes ago, qwerty8224 said:О да вашейв😉
Are you referring to me?! If so, thanks.
7 minutes ago, smartavionics said:
Вы имеете в виду меня ?! Если так, спасибо.
Yes )))
burtoogle 508
Hello @nobio8, looking at your gcode, it appears to do something wrong in the middle in that it does a skin line parallel to where the gap is and then does another skin line directly on top of the first when it should have done the second skin line where the gap is. I would guess it's a bug in the concentric skin fill.
