Just for plays I created a gcode file you can test with.
The file is a a print job that will move to the 3 manual levelling locations and remains 5 seconds at each location before moving on.
Since you didn't mention your printer model I created this for the UM3. For the other printer models you'll have to change the head positions.
Note that manual levelling is only to be done when you think something changed in your printer or its environment. There pass multiple months where I don't re-calibrate.
1
hyiu0000 0
Actually I wonder if there is a way to generate a G code to home the print head to the three points without printing?
