Small bug in 4.0 Final
Aybom
Posted · Small bug in 4.0 Final
You can expand the profile list downward now, but then it blocks the dialogs at the bottom. Also, in preview mode, this panel sits in between the model and the layer slider, instead of all the way to the right where it would be out of the way.
    I've found a much bigger problem with the Settings pane. On a Mac, I tried to move the bottom edge of the pane downward, and it jumped to the top. Now, when I try to drag it down, it goes up. And when I try to scroll it up, it goes down. And the largest I can expand it is so such that it shows about 2 settings! It is now impossible to use!
    The attached ZIP file has  a video that shows the behavior.
    Cura 4 Bug.zip
        • 31 replies
        • 25 replies
