You can always go back to an older version using this messy method:
@ctbeke - is there a way through ssh to turn off this flag? Would that let him then upgrade to 5.2?
Oh wait - if he's not in developer mode he can't use ssh and he can't get to developer mode because he's stuck on an infinite popup.
I think he's going to have to use the unbricking procedure above.
A reseller just told me that when they get this infinite loop issue the only recourse they know of is to use the unbricking procedure I linked to above.
Thanks @gr5. I flashed the recovery.img and booted from it. After a while, the dial went green and the LCD said to power down and remove the SD card. After doing that, rebooting normally, and going through the initial setup, the printer was running firmware 4.3.3.20180529. I was then able to upgrade to 4.3.96.20190313, then 5.2.8.20190320. I haven't run a print job yet, but the menus and network connection seem to be working.
Yay!!!
gr5 1,999
Maybe try cura connect?
FYI - version 4.3.96 is a "stepping stone" version intended to never be used to print but intended to let you upgrade to version 5.2. So if you manage to unbrick it you still need to do one more upgrade.
