Posted · New Layer Nozzle Positioning
So I'm trying to figure out which setting might be causing this, but can't seem to find it. After updating to a new Cura version, I started noticing my extruder moving to the same starting position every new layer.
What I mean:
After a layer is finished printing, regardless of where it finishes it always goes back to the same place on the print; due to sometimes long travel distances to get there and certain retraction settings, this is causing that certain location to have less material.
What I had:
The new layer used to start printing right where the previous layer finished, regardless of its position.
I assume it's doing this to increase print quality and/or the look of the piece, but I'd rather have it back the way it was. Any advice would be greatly appreciated.
(I'm using CURA 4.0, and can upload settings if needed)
Thanks.
    Hello @naten11, it sounds like you have upgraded Cura from quite an old version because for some time now the behaviour has changed to what it does now. i.e. it always starts the layer at the same location irrespective of where the previous layer finished. It now behaves this way because the gcode for the the layers is computed concurrently rather than sequentially so it doesn't know where the last layer finished when computing the gcode for the next layer.
    • Thanks 1
