bob-hepple 59
Tinkergnome
Thank you for replying the oscillation has only raised its head since I installed the new Mark two, On the original head I am still ysing the original heater but I am using 3dsolex blocks,, I did suspect it was the Pid setup (sub-optimal) don't know this,, but I had done a Auto pid tune, but as I said the Temp is ramping up by 20 then back down although I don't know where 200c comes in when S3d has it set to 210,, (could be creeping)??.
The link gives plenty of warnings but light on how to?? for the novice,,, I have Pronteface installed so might have a look on that,, Ill also print the link off and have a go at manually setting
at the moment my settings for Head 1 are
Kp 18.83
Ki 3.64
Kd 24.38
this was after a Auto Tune
tinkergnome 917
There are no changes in heater management that i'm aware of.
It sounds like sub-optimal PID settings....?
Are those different from the former setup?
I think the "Troubleshooting" section of this post is quite handy:
How-to: Quickly hand-tune your PID values
