thanks - but wasn't CPE supposed to be more thermoresistant than PLA?
CPE is a little more heat-resistant than PLA (up to 70°C), CPE+ is said up to 100°C (I've not used CPE+ so far, only CPE), but with water temparature up to "hand warm" (starting temp, no heated bath) i never had problems with after-print warping.
Also, I am not sure if it has anything to do with the water. I submerged it immediately together with the glass plate. Maybe it is just the temperature shock.
kmanstudios 1,120
On 4/20/2019 at 11:50 AM, aag said:Also, I am not sure if it has anything to do with the water. I submerged it immediately together with the glass plate. Maybe it is just the temperature shock.
I would go with this. I would let the print and plate thoroughly cool before submerging in water.
Enigma_M4 122
I've read somewhere at the Ultimaker-Homepage, that the water used to dissolve PVA should only be up to 30°C, but they recommend use of cold water.
Greetings
