Firmware update for dual extrusion
Posted · Firmware update for dual extrusion
I've got a question about the update of the firmware for dual extrusion. I've just use the function called "Install default marlin firmware" in Cura. Is it enough ?
Is it possible to check the temperature of the 2nd extruder with the ulticontroler and move the 2nd motor for extrusion ?
    I will check this evening. I undestood why the first time it didn't work. I updated the ultimaker before selected 2 extruder in the preference of Cura. So the ultimaker was updated with the firmware for only one extruder.
    So now, i've got the temp for the 2 extrudeur, but I think it could be improve :
    http://umforum.ultimaker.com/index.php?/topic/3013-improvement-for-the-dual-extrusion-firmware/
