tinkergnome 923
simply search for the keyword "ERROR" and you'll find:
[...]\AppData\Roaming\cura\4.0\extruders\custom_extruder_7+%232.extruder.cfg:
custom_extruder_7 #2: Missing required section 'general' or 'version' property
Thank you tinkergnome for your answer.
ok, I see how to find the problem, but how could I fix it? (I'm new and also I have no idea about Backend "things"). Or could you forward me to another thread in the forum with similar problem/fixing?
I looked for "error" in the file and... hundreds? thousands?
The trick is to look for "ERROR" - in capital letters - there are only a few. 🙂
There are no public instructions or explanations about these files that i'm aware of.
Personally i would compare the file content with similar files in the same directory (if any).
I guess you can simply delete (or move) the file and it will be re-created during the next start of Cura.
(but keep the according *.json files).
If this doesn't work, you need someone that is more familiar with Cura config files...
Thank you for your tinkergnome answer.
That point about capital letters is crucial... I couldn't imagine that.
I will try to follow your advice.
fundamental4 0
I've seen in another thread that Cura log file is useful. Attached. (it is full of warning and debug lines).
cura.log
