6 hours ago, RudydG said:Found this: https://www.thingiverse.com/thing:3319232/comments
Seems to be the safe solution at this moment?
I am using this latch on all my printers and it works fine. The Thingiverse latch is 1mm too long, so I redesigned it to get a better fit. S5-PrintHead.stl
ultiarjan 1,215
are you sure you mounted the silicon pad correctly? maybe share a photo or even better video?
Can you simulate by manually moving the BB core up and down (manually with the side lever) and will the head then pop open?
