Posted (edited) · Ultimaker 2 Go print volume problem
The Ultimaker 2 Go is advertised as having a print volume of 120 x 120 x 115 mm, but I am frequently unable to print objects smaller than that. I get a message from Cura saying that it is unable to slice because the model doesn't fit in the print volume. I have Support and Adhesion turned off, so they shouldn't affect the print volume. I've attached an example file that won't print on my Go, even though it is significantly smaller than the Go's advertised print volume. Is the Go's print volume smaller than advertised? Or is there a bug in Cura?
go_test.stl
Edited by JimT
          • Heart
        • 4 replies
