Active Bed leveling causes extrusion too close to bed
BenKerno
Posted · Active Bed leveling causes extrusion too close to bed
Hi, I recently got a Ultimaker 3 extended (through work) and I've been testing out prints on it regularly. for some reason when I use active bed leveling the nozzle extrudes the first layer too close to the build-plate resulting in a bad first layer that is larger than the rest. I can solve the problem using manual bed leveling and I've looked into it and it looks like there is a way to I inject a G92 Z-.1 line in to the start of the Gcode to fix this problem, but it means I cannot print over the network. For a $5000 printer there must surely be a solution. thanks
    We should first look, why you mean that there is a problem with the first layer. Active leveling works fine without problems.
    The first layer is a little bit larger than the other layers because you want to squish it well into the bed to get good adhesion. You can compensate it with "Initial Layer Horizontal Expansion", set it to -0.2 or -0.3 to get rid of the so-called "elephant foot".
    In my opinion, there is no need to add a G92 into the header. Besides that, with the current firmware, there is bug/problem, that the G92 commands are not working as expected, so you should avoid it.
    BTW: One post is usually enough, please avoid to post 3 times the same message, you will not get more or faster replies due to that. (to avoid confusion, I deleted the two other ones)
    You are lucky you have the UM3 - you can simply turn off active leveling.  It only levels tilt and height anyway (it's not multipoint leveling that corrects for nonflat glass).  So I recommend you do manual leveling.  You can tweak it slightly over the next few prints but at some point it will be perfect for your needs and you can just leave it there forever.
    But note that I like it when it is "too close to the bed" as then the parts don't come loose during a print.  And you can compensate for the little "elephants foot" by setting "initial horizontal expansion" to a negative value - around -0.3mm.
