Thank for reply
I mainly use ABS best result weld easily hard ect. Can you weld Nylon together or just stick
Thank for reply
8 minutes ago, gromit said:Can you weld Nylon together or just stick
I am not sure what you mean by 'just stick'. I have not tried to weld Nylon before, but, it is a plastic and as far as I know, all plastics can be welded.
acetone melts ABS together , is there any thing that melts Nylon together with out killing myself
That is my limit on plastics chemistry...sorry. The other option would be a glue. I really like this product called "Serious Glue."
Thanks again
I will buy a real of Nylon to see what kind of finish i can get + some serious glue. Then look for a 3.
thanks GROMIT
I bought a spool of HydroFill from AirWolf3D but have yet to try it out. It was formulated specifically for ABS prints.
Let me know how you get on.How it dissolves and how long it takes, and finish between AirWolf3D/ABS. As i said instead of printing in 2 3 4 parts ,then weld together.IF it works no more compromise on how it print and design things.
Thanks Gromit
Edited by gromit
kmanstudios 1,100
I thinhik the UM Breakaway material would be your best bet in general. I do not know of any water soluble material that works with ABS. And, believe me, I tried.
Works great with Nylon though.
