Here is the boat. You can see every time there is a retract, its all alone on its own line. and the longer the bowden tube, the longer it needs retracting, and the longer it sits over the part while its retracting.
Is there a solution to this, maybe a setting for a work around?
And I know the code says I am retracting at 65mm/s, but I can visually see the printer stop while retracting for a good 1-1.5 seconds.
This very well by my firmware and arduino brains causing it as a 2.5mm retraction at 65mm/s should be virtually instant, but its not. Thats why I am hoping there is a solution.
Edited by changedsoul
burtoogle 505
Hello @changedsoul, please attach a gcode file that has this problem. Thanks.
