DivingDuck 85
Had you already try to check -->Shell ->Print thin walls?
An other way is (depending on your actual setup) to reduce line width in -->Quality -->Line Width a little, eg 0.399 fore a 0.4 nozzle depending on wall the thickness you need.
BillieRuben 0
Anyone know any settings I can change so it prioritises long lines instead of hatching?
