Where can I find the error log in the first run wizard?
I've tried loading the code on the uC manually using avrdude and I get this:
This is my problem in Cura:
The BAUD rate in my device manager should match the baud rate in cura right? Also where can I find old firmware, stuff that will work with ReplacatorG 24? If I can't get this to work I will just have to downgrade.
Daid 304
Cura should give an error log if it failes to connect. This might provide an insight into why it's not working.
