hmmm then the software that came with my machine is backwards....
The way I read it though when enabled it is supposed to avoid already printed areas when traveling.... it does not and smears the layer with lines. OFF works so I am just going to keep it off.
In my mind retractions are a MUST for a clean print...
Rob
burtoogle 505
Hello @rob0213, that's how combing is designed to work. Combing does not normally use retractions when moving the nozzle within a single part. There is a setting called something like max comb distance without retraction, when you set that to a non-zero value, combed travel moves further than that distance will use retraction. The best quality results are often achieved by setting the combing mode to not in skin and using a non-zero value for the max comb distance... Hope this helps.
