The first line tells the bed to go to 0.1mm. The second line tells the printer to from now on (until the z axis is homed) consider that position as 0mm. So effectively every following Z coordinate will be 0.1 mm further away from the bed then after homing the z axis.
ahoeben 1,992
This is correct.
TMicke 23
Thank you! That explains it perfectly to me.
/Micke
