Dual Extrusion with Kisslicer is working
Posted · Dual Extrusion with Kisslicer is working
http://www.calumdouglas.ch/3d-printing/ultimaker-3d-printer/adding-dual-extrusion-to-ultimaker/
At the top of the page you can download a ZIP archive with all the stuff
needed to make this work. I cannot post any pics because my main heater
cartridge just failed so currently out of action.
ZIP Contains:
Kisslicer exe (for windows x64)
Firmware modded for dual ext.
Kisslicer setup files modded for dual ext.
Sample test STL part and pics of how it should look
Let me know how you get on, but it all works for me. However I only
use it for printing support in 2nd material. Have never tried it as a
"dual material" print....
    Isn't dual-extrusion a PRO feature in KISS? (not that I'm against PRO features. Jonathan is a great guy and deserves the money. Just wanted to warn people who want to try this)
    I have the Pro Version. But it is not working for me. With the actual firmware from Cura the offset setting are not working. (they will be ignored) I have the problem with kisslicer and netfab. With Cura everything works fine.
    @snowygrouch: Where can i get the hex-file for updating the firmware? Or have i compile it myself?
    ok, perhaps i am a little bit stupid. I download your Zip and i am search for the hex file to install the firmware with Cura, but i can not find it.
    When i am looking to your Guide i see, that i have to install the Marlin developer suite. Perhaps you can tell me where i can found the Hex-File i have to install the firmware without installing the Marlin developer suite?
    OK I understand now,
    You need to install this with the official Arduino software.
    http://arduino.cc/en/main/software
    Download Arduino IDE 1.0.5
    You should learn how to install firmware this way, as you will also be able to edit the
    firmware in Arduino IDE (if you ever need to in future).
    To compile it is explained here:
    http://www.calumdouglas.ch/wp-content/uploads/2013/04/ARDUINO_COMPILE.png
    Once compiled you just click on FILE>UPLOAD and thats it. To do the whole process is only
    3 mouseclicks. Once to load the firmware into Arduino IDE, once to compile it, and once to upload it.
    Let me know if you need further help. (in my website, its explaining how to edit your
    own firmware so it works in dual extrusion, you do NOT need to do that part with the
    files I provided here - that bit is done already)
    Regards
    C.
    Thank you it works
    Great !
    I'm keen on the ultimaker 2 as my first printer, but I want to have dual extrusion option within the near future. Do you guys see it becoming available on the 2 or will we have to wait for quite a while?
    Has anyone had achieved simialr success following "snowygrouch's" process for Dual Extrusion printing with PLA/PVA?
    Has this process been supplanted by other methods that have been posted since this?
    Never mind. I was just on his web site and found what I was looking for..
